OffshoreOnly Boat Classifieds Sale
Go Back   Offshoreonly.com > Technical > General Q & A
Register Upgrade/Renew Membership Forum Rules Search Today's Posts Mark Forums Read
OSO Sponsor
NorTech
OSO Sponsor
NorTech
Advertiser
Advertiser
Thread Tools Search this Thread
Old 09-09-2008, 05:10 PM   #1
Boat Nut
Oldie Formula, 272, 26 Infinity & new 33 Avanti
Brass, copper fittings in Stainless strainers?
Is it OK to use brass or copper fittings in a stainless sea strainer? Any dissimilar metal issues?
I have a tough tiime finding stainless, 1 1/4 NPT thread to water/hose barb pipe fittings.
PARADOX is offline   Reply With Quote
Old 09-09-2008, 05:19 PM   #2
Brass is the gold standard for breaking the dissimilar metals chain. That's what you use on connections between steel & copper. But you're going to rubber anyway so it doesn't matter.
Chris Sunkin is online now   Reply With Quote
Sponsored Links
Old 09-09-2008, 05:24 PM   #3
Boat Nut
Thx..
Teage sea strainers. SST./chrome... 1 1/4 Female NPT.. I need a male hose barb to go into the strainer so I can clamp the hoses to it. I found copper, for 1" hose. Found brass for 3/4' hose. Can't find stainless anywhere. Macmaster and Carr has something but I can't be sure it's a 1 1/4" NPT thread.
Old 09-09-2008, 05:31 PM   #4
Offshoreonly Advertiser
Quote:
Originally Posted by PARADOX View Post
Thx..
Try these out. Go all the way to the bottom of the page, straights, 45 degree and 90 degree.
CP Performance
www.cpperformance.com
One Free Call Gives You Access To Over 500,000 Items!
800-225-9871
CPPerformance is offline   Reply With Quote
Old 09-09-2008, 05:33 PM   #5
BOATLESS FOR NOW
I think I have 4 of them at my house I'll check when I get home.I live in NPR you looked at my 37 AT
OutlawMark is offline   Reply With Quote
Old 09-09-2008, 05:40 PM   #6
BOATLESS FOR NOW
these are what I should have
http://www.cpperformance.com/detail.aspx?ID=1028
Old 09-10-2008, 10:07 AM   #7
Boat Nut
Thanks Mark,,, Those might work ok, I was trying to get stainless.. I remember your boat... saw it in the oso adds, and I see the price is better now.
You got to take that beast out.. Let me know when.. I might join you for a run or something.
Old 09-10-2008, 10:42 AM   #8
If you're screwing stainless into stainless, use a good liquid teflon pipe thread sealant or the bronze-based anti-seize. Or both. They may not gall going in, but they probably will coming out.
Old 09-10-2008, 04:20 PM   #9
BOATLESS FOR NOW
Probably be out this weekend,weather looks good
Old 09-10-2008, 05:11 PM   #10
1972 Cigarette 36 race
Are you sure that is 1 1/4 thread? Typically the strainers are built with 1" NPT which happens to be close to 1 1/4 OD (standard merc sea pump inlet size).
We normally buy 6" x 1" npt nipples, put them in the lathe chamfer and turn down enough room for double clamps leaving a lip on the end. That way we get 2 fittings per nipple.
Marc
www.mercruiserparts.com
www.go-fast.com
and coming soon - www.BamBoatGear.com
Mbam is offline   Reply With Quote
Search this Thread:
Advanced Search
vB code is On
Trackbacks are Off
Refbacks are Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Stainless, Brass, and Aluminum .... txriverrat2001 General Q & A 6 08-13-2008 02:24 PM
Stainless Marine strainers/382 RedDog382 General Boating Discussion 2 05-16-2007 05:09 PM
Stainless Steel AN fittings needed bobl General Q & A 7 03-14-2006 08:36 AM
Stainless steel AN hose fittings NOBODY General Q & A 1 03-02-2005 08:51 AM
Where can I buy a 34" of 3/8 stainless double flared with the fittings mkforsberg General Q & A 4 01-23-2002 01:23 PM
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
Copyright 2008 OffShoreOnly. All rights reserved.
