Merc 502 Oil Cooler, Rear Mounting
I'm told I need one of these. It's the rear mount one, above the bell housing (not the low side mount). Anyone have a P/N or source. Thanks.
I have a aftermarket one thats 17" long oil only(no p/s) 1 1/4 hose that I'm not using any more, email me if you are interested @ [email protected]
Where To
http://www.offshoreonly.com/forums/s...d.php?t=195086
Factory HP500 New lines and brackets. Follow the link!
PM me with questions.
Dave
Dave
One thing to keep in mind (this applies only to MPI's) is with a bellhousing oil cooler, your "Cool Fuel" setup is now plumbed after the oil cooler. If you are up North or offshore this probably will be no problem, but on inland lakes during the summer, heat-soaking/vapor lock has been a problem for me in the past. If you want the big bell housing cooler and the mpi then run a return line to the tank or you can do what I did and buy the "enhanced 502 mpi cooler" from Marty @ Lenco Coolers...this cooler goes in the stock location, has appx. 50% more cooling capacity, and has much less restrictive oil bungs. And its cheaper than you think. I just mounted mine last night and am now planning to install a 203* mocal t-stat on the filter pad...should end up pretty clean - I'll let every know. Thanks to Arcticfriends' oil thread for the inspiration. Take Care, Dave
