Oil in Puke tanks Blower motor
i run speed pro rings with alot of ring gap on my 32 skater 15psi boost @7500 rpm will have blowby in puke tank let it happen thats what puke tanks are for at least the rings wont expand and butt together it makes big power 1230 hp 1140 lb torque its old school roots blower set up but if it aint broke dont fix it
Also if your running to much piston to cylinder wall clearance your rings wont last as long.
Rob, what do you call loose as far as piston to cylinder clearance? Why do you have to replace the blocks? What is the bore now? If they are Gen VI blocks, they can go to 4.600. All and all, even at 15% on an sc engine with over 100 hours, that's not bad.
I got a piar of 598's that will leak less than 5% right now. 14 holes will go less than 3%. They have not been fired in a month. So will Joe Murray's 598's.
Yeah........REALLY!!!
Rob
thats dayum G@@d #s BIG Daddy ,must be them big hp motors cause down here fresh off the dyno there seeing 8 to 10 %
maybe we should use these Speed Pro plasma for a game of ring toss
Try these.
I figured 15% was soso,Also meaning nothing is hurt. Gen 6 2001,The pistons call for 6.5, most are around 8 one is 10 and 11.theres alittle scuffing on the pistons,its been like that for the last 2 ring jobs, one is 30 and one is 60, I was thinking taking the 60 over to 70, but they say they don't make rings for them. I really didn't want to go past 70 over.I'm scared of it being thin.I see they make a ring for a 4.560.I wonder if thats a off the shelf piston?
Rob
Rob
You can Also try C&A rings.
I have 2 builds on Childs and Albert rings they have a zero gap setup very similar to speed pro.
Looks like they have your size as well.
Yeah 15% is the early end of getting tired.
Not bad, but not new. Another season it will probably be time.
"Uncle Dave"
Laveycraft 2750 Ilmor 710
Laveycraft 20.8 Sebring 406 SB
It's not Speed Pro rings, they are Total Seal Gapless TS1.
Rob,
The 4.560 is a shelf piston. You should not have any problems going that big. Like I said, I regularly take Gen VI blocks to 4.600. I have taken a few to 4.625, but they do get a little thin. Have the block sonic checked and be sure to leave at least .200-.250 wall thickness. It all depends on how much core shift the block has as to how thick it will be. You will have one side of the cylinder wall that is thicker than the other side because of the shift. The other deciding factor is salt water corrosion from the back side. Salt water will eat the back side of the cylinders and make them thinner. So in theory, a fresh water block will have thicker cylinder walls than a salt water block.
Eddie
Eddie
