Whats the Difference between Bravo drive couplers?? >
Old 04-19-2009, 02:04 AM
Rob
Strip Poker 388's Avatar
Originally Posted by articfriends
I switched to the long snout steel years ago after my std one had the splines looking 1/2 rolled out of it. The longer hub makes it much harder to get my engine into the boat as I have very little front clearance (I actually have to install my front crank pulley once motor is in the mounts)and it seems harder to align but more accurate once it is. You literally can't get the input shaft to go in if it isn't 99% perfect,you won't regret buying them though once it's in,Smitty
thanks,I think ill be OK on the install, the alignment has always been a b!tch thats what I figured,A headache, Ill be taking it easyer on the drives , I clould of bought another drive for what the rebuild cost,upper gears are
Strip Poker 388 is offline
Old 04-20-2009, 09:37 AM
hoghead's Avatar
Originally Posted by Strip Poker 388
Did it make it hard to install the moter with it sticking out , also did make it harder to aline the engine??? I just bought the A20, they just went up again Jan 1
Rob
I didn't find it any more difficult, but I have a single engine with lots of room in the engine hatch. I also have solid motor mounts and my alignment remaind the same. I checked the alingment after installed and the tool slid in nicely...
hoghead is offline
Old 04-20-2009, 04:57 PM
Rob
mines allways a beoch to alignment,I can turn the motor 180 and it changes it on the tool,
Old 04-20-2009, 06:27 PM
blue thunder's Avatar
I just dropped my engines in with new couplers and aligned them. Then I turned them both over and tried the tool again. One slid right in the other was tight. I tapped the tool up down right and left with a dead blow and the tool would slide right in again. I think the engine needs to actually run with the drive shaft in it to get the gimbal bearing lined up perfect I replace the gimbal bearing on this side.
blue thunder is offline
Old 04-23-2009, 01:43 PM
hoghead's Avatar
I've run into the same scenerio on an older boat I had. After reinstalling and initial alignment check, found I needed to "adjust" the gimble bearing and recheck.
hoghead is offline
Old 04-23-2009, 04:37 PM
Rob
Ive done that also,spin it over then push the tool up down and sides,I think the rubber hub moves around when its running anyway,
Old 04-23-2009, 11:05 PM
2112's Avatar
I am not sure anyone cares but the long snout will not work with the input shaft of the adapter used on the front end of a drive shaft in a staggered configuration.
Well, on mine it didn't.
2112 is offline
Old 04-25-2009, 03:32 PM
Rob
try these
http://img134.imageshack.us/img134/6318/2112custom.jpg
Old 05-21-2009, 08:54 AM
What couplers did you use and where did you get them?
tbanzer is offline
Old 05-21-2009, 06:04 PM
Rob
Talking
I bought the a20 has the snout,claims stronger rubber etc,
the a9 is the next best,thats what I have still on the port motor,original 2001.
Mid Stream marine {racerx6] Eric/Wendy 9856402097
Aftermarket Marine [Sean]18007697698
both are members here,Tell em I said hook ya up
Quick Reply: Whats the Difference between Bravo drive couplers??
