Go Back   Offshoreonly.com > Technical > General Q & A
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 03-16-2002, 11:40 AM   #1
Kent Perroux
Core Material
Does anyone know what composite material Apache is using in thier transom and stringers now? Eric (with Apache) was showing me some pretty stong black material they were using now last time I was there. I forgot the name of it. It is being used in place of plywood and is very strong.
I am redoing my transom and beefing up my stringers in the engine bay and want to use this material.
Kent
Old 03-16-2002, 05:35 PM   #2
2008 Gunshow
Kent:
I can't say for sure what core material apache uses. It probably is balsa core.
Baltek Corp. is a large supplier of balsa core.
http://www.baltek.com/products/egbc.html
vtec
vtec is offline   Reply With Quote
Sponsored Links
Old 03-16-2002, 07:43 PM   #3
Charter Member #232
Audiofn's Avatar
1979 Formula 302
If I was to guess I would say it is a high density Foam. Could be 12 pound foam perhaps. It is called a couple of different things Like Davinicell and some others that are not coming to my mind right now but lets just say for arguments sake it is foam. If you have not seen the price on this stuff you better sit down it is NOT cheap. I did my transom in Marine Mahogony. The old transom lasted 21 years so all things equall the new one will last much longer. Either way it is WAY longer then I plan on keeping the boat
Audiofn is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
So you think you are a hard-core boater ? DonziDog General Boating Discussion 46 10-14-2008 09:59 PM
core-cell sd11856g Fiberglass and Paint 0 01-09-2007 11:15 PM
Getting core and glass bshzba Fiberglass and Paint 3 11-19-2006 12:07 AM
Where to buy balsa core THRILLSEEKER General Boating Discussion 5 09-08-2005 06:15 PM
Search Engine Optimization by vBSEO 3.2.0
