first time addjustment
When installing a new set off hydraulile roller lifter,pushrods, and roller rockers (they have not been pump up) For the first time do you turn down onr turn or 1/4 turn 1999 BBC.
Take a squirt oil can and fill them thru the small hole in the side of the lifter before you put them in. Install them and set 3/4 turn preload. We put a little extreme pressure lube on the pushrod tips. I also spray the valve springs and rockers with the Comp Cam assembly spray.
lifters
Would priming the engine through the distribor hole with a electric drill do the same thing. The engine has been sitting all winter anyways?
Ken N.
TeamRelentless
General Racing Discussion
2
03-08-2004 03:41 PM
