Motor Guru's
OK I have another question I need help with.I thought I had 8" deep oil pan.But I was just setting up the oil pump,Melling Select 10777 with the screw in pick up,and it seems the pan measures 9" with gasket in place.Does this sound right?When I measure the old pump and pick up it measures 8-7/8". So Im assuming I have the wrong pick up but do they make a pick up for this pump in 9"?
Thank Anthony
Thank Anthony
Thank Anthony
Thank Anthony
One more question about this melling 10777 oil pump and pick up.When I screw the pick up into the pump should I red lock tight it in? or hit it with the mig in a couple spots?Whats everyone else doing to seal the tube so it doesnt have any air leaks and dont loosen and drop to the bottom of the pan.
Thanks Anthony
Thanks Anthony
