496 mag question?? >
496 mag question??
496 mag question??
Old 03-29-2009, 04:55 PM
Default 496 mag question??
A 2003 496 mag. is it a closed cooling system? Is it even an option or are they all closed systems. Also, how do you convert a 496mag to a 496HO? The boat in question does not have captains call I am assuming that it is not neccessary. Thanks
risky is offline
Old 03-29-2009, 05:38 PM
GO4BROKE's Avatar
All 496's have closed cooling. There are a few threads here on converting to HO. All it takes is a cam and computer. The captians call has nothing to do with it.
[img][/img]
GO4BROKE is offline
Old 03-29-2009, 05:54 PM
Default Captains call
I was thinking a 496ho would run better with thru hull exhaust that is why I mentioned it. Thanks for the help I will do a search
risky is offline
Old 03-29-2009, 05:59 PM
all merc 496 are closed cooling
some volvo 496 are not
boatnt is offline
Old 03-30-2009, 09:48 PM
crayolacrazy's Avatar
I have two cams 375each 850 each to get your ecu redone
crayolacrazy is offline
Old 04-01-2009, 08:36 AM
Mr. Cool's Avatar
If you go to a 496 HO you may need to increase your cooling capacity. Check your engine temps and if they take a spike, you'll need to increase the size of the heat exchanger unless you can increase your seawater flow to overcome it. We can get you the heat exchangers if you need them.
Mr. Cool is offline
Old 04-01-2009, 12:26 PM
Received 1,821 Likes on 907 Posts
Closed cooling has nothing to with thru hull exhaust.
Yes, it would make more power with thru hulls.
Griff is offline
davis777
0
02-01-2006 12:27 PM
chrisf
01-14-2006 11:31 AM
davis777
11
01-07-2006 09:34 PM
BaggerOne
0
04-05-2005 01:48 PM
Von Bongo
08-14-2002 11:06 PM
Quick Reply: 496 mag question??
