Innovate air/fuel ratio meter
I think your #'s look pretty good and safe. I don't believe you want to be any higher then 12.2 on a NA engine from what I have read.
I also like my LM1. isn't the LM2 dual recording for both banks?
The LM2 is single or dual. I went single (odd cylinder bank) because it would be a tough squeeze getting an 02 bung in a dry spot on the exhaust on the even side - I have exhaust diverters. There's more room on the odd side but it's still really close to where the water enters the exhaust. My CMI Sport tube headers don't have much tailpipe before the diverter valve.
Had a great day on the lake yesterday. I still can't figure out how to recall the air/fuel ratio data logs, it keeps coming up "invalid data file". I will have to phone Innovate on Monday-I'm sure it's something simple that I'm missing.
I got the wife to write down the a/f ratio's at 500 rpm increments, made four runs. Seems rich at idle/low rpm, not sure about the rest, what do you guys think?
5000 rpm is the most I could get with a labbed 28p bravo.
My thought is your AFR is safe/typical but rich. The pro-engine builder has little motivation to put the AFR ratio any leaner especially not knowing each use/load and the fuel being used.
If you leaned out your set-up a full 10%, how many fuel $ will you save in a season?,,,$150-300? Is it worth it?
Having said this, I haven't stopped working on my to get it right on the money
Do you have set a target AFR at each RPM? How many test runs is your wife good for?
I don't have a set target for the AFR, but I have a lot of transom soot that I would like to reduce if possible.
The wife will do more AFR test runs as long as the beer cooler is full and she gets some time behind the wheel!
BenPerfected--
Getting the AFR right is also about making horsepower. When it is too rich, you are wasting fuel and available horsepower.
IMO for N/A motors, you are a little on the rich side and you confirm that with the black transom.
Smitty,
I agree and believe that an engine in tune will make more power. Rich leaves the plugs half fouled and cuts the life span of the oil and may increase wear. On our mid-July trip, I am targeting 13.4-13.6 from 3000-5300 RPM and from 12.6-12.8 at 5300+ (PV's open).
Smitty,
Hi ! Is there a part number for the FAST kit or components needed ? I would like to get setup to use the 1/4" NPT threads on stock Mercruiser exhausts, as well as the CMI headers. I would love to use this on a 383 I just installed in a buddy's boat to get it jetted perfectly. Thanks, BBB
I will talk to Dustin at Whipple - I'm running Whipple's Stage 2 ECU, so hopefully he can retune it leaner.
