wt headers can i get away with this cam??
I did run a crane 139651 244 - 256 with CMI elbow tops with no trouble with reversion. Not saying it do not have any just did not cause any problems. There is a lot of variables to say what will and will not work besides just the cam.
I ended up going with another crane but I looked hard at the same cam you asked about. Curious what it is going in and how it works out.
Only the Best Will Do!
Well I can confirm that with a standard Bravo type wet system that we don't know of a way to accommodate these cam spec's at .050. A dry tail pipe system will work or a custom long tail pipe discharging water just prior to the transom may work . Caution make sure if someone says they can do it with a standard wet tail pipe that you have some recourse when/if it doesnt work and destroys your engine.
Has anyone ever use this cam. I've always seen it around and looks OK with the exception of the higher duration. Just wondering???
Part Number: 134571 Grind Number: H-306-2 (REPLACES CCH-306-2)
Engine Identification:
Start Yr. End Yr. Make Cyl Description
1967 Up CHEVROLET 8 ROUGH IDLE, PERFORMANCE USAGE, GOOD UPPER RPM HP, BRACKET RACING, AUTO TRANS W/ 3500+ CONVERTER, MARINE PERFORMANCE, 4000-4400 CRUISE RPM, 10.5 TO 12.0 COMPRESSION RATIO ADVISED. BASIC RPM 3800-6800
Engine Size Configuration
396-454 C.I. V
Valve Setting: Intake .000 Exhaust .000 HOT
Lift: Intake @Cam 336 @Valve 571 All Lifts are based
on zero lash and theoretical rocker arm ratios.
Exhaust @ Cam 344 @Valve 585
Rocker Arm Ratio 1.70
Cam Timing: TAPPET @.0042
Lift: Opens Closes ADV Duration
Intake 44 BTDC 82 ABDC 306 °
Exhaust 92 BBDC 42 ATDC 314 °
Spring Requirements: Triple Dual Outer Inner
Part Number 99893
Loads Closed 130 LBS @ 1.850 or 1 27/32
Open 342 LBS @ 1.290
Recommended RPM range with matching components
Minimum RPM 3400
Maximum RPM 7000
Valve Float 7200
Cam Timing: TAPPET @.050
Lift: Opens Closes Max Lift Duration
Intake 16 BTDC 50 ABDC 107 246 °
Exhaust 64 BBDC 10 ATDC 117 254 °
396-454 C.I. V
Part Number 99893
Minimum RPM 3400
Maximum RPM 7000
Valve Float 7200
