Like Tree0Likes
engine noise?
Old 04-22-2009, 06:44 AM
  #31
My Boats: Checkmate 251 Convincor(sold),Checkmate 253 Convincor(sold), 50 gibson, 21 Eliminator Daytona, 25 Sportcraft Center Console
looks like that one was too loose...appeared may have been hammering the rocker before the pushrod gave up...also what push rods ? did you ck for proper lenth ? Rob
ezstriper is offline
Old 04-22-2009, 06:57 AM
  #32
blue thunder's Avatar
My Boats: 330 Carver 30' Scarab Panther 17' ProV Lund
You say you set them at zero lash then 1/2 turn. How do you difine zero lash? It takes a light touch with new lifters to find this spot.
blue thunder is offline
Old 04-22-2009, 08:03 AM
  #33
My Boats: Baja 24' Outlaw Marine Kinetics Build
Quote:
i got them from my local speed shop. i told him what lifters i had and rocker setup and he ordered them. do you think i have the incorrect length pushrods. and what is the best way to find out what size i need?
Fixxxer22 is offline
Old 04-22-2009, 10:08 AM
  #34
Brad Zastrow's Avatar
I would seriously consider pulling the head(s) to check the valves. Way cheaper to do that now than lose the valve later into the engine. I would also suggest having a pro set the lash. Little mistakes cost so much. I would not gamble an engine at this point. Take it to an engine builder to get your setup right. I use Ateco even though I know how to do this stuff. I have spent too much money fixing broken engines because I was trying to do it myself. Hi-performance parts go bad on little mistakes. That is why now I only use experts for my two strokes and four strokes go fast stuff. I was rebuilding these things when i was kid with success with stock parts and stock engines. Hi-perf is a all new game.
Brad Zastrow is offline
Old 04-23-2009, 11:30 PM
  #35
My Boats: 1994 Baja 236 500HP
Quote:
Don't get depressed. Figure out what went wrong and fix it. Learn from your mistakes and move on. If you don't think you can handle it, find somone local that you trust to help you. Good Luck!!
jeffswav is offline
Old 04-24-2009, 06:11 AM
  #36
they would have no way of knowing for sure what lenth would be correct, they sell a test rocker arm and a adj push rod to check for the correct lenth...Rob
Old 04-24-2009, 08:11 AM
  #37
Trade Score: (1)
EWPE's Avatar
My Boats: 16 Glasspar Citation ,30 Concept SD
Quote:
Good advice!
EWPE is offline
Old 04-24-2009, 01:05 PM
  #38
Start by removing a rocker from one intake and one exhaust valve. Clean the end of the valves with thinner. Sharpy marker the end of each valve and reinstall the rockers and adjust properly. Turn the engine over 2 or 3 revolutions. Remove the rockers and look for a bowtie shape approximately centered on the valves in the marker. If you have that, you pushrod are the right length.
Old 04-24-2009, 01:25 PM
  #39
Trade Score: (1)
My Boats: 40 Skater 607Ci 14:71 TF Kobelco
Default engine noise
Bring it to Loto You do drywall I fix boat
Thumper
thumper038 is offline
Old 04-24-2009, 05:53 PM
  #40
My Boats: 96 , cig top gun
Quote:
well i would at least leak it down.... something sure as hell bottomed hard...
stevesxm is offline
