ProCharge a Merc 420? >
Old 03-27-2002, 11:48 AM
Sean's Avatar
Default ProCharge a Merc 420?
Anyone ever install a ProCharger on a 420? Will it handle 3-5lbs of boost? How much HP gain?
Sean is offline
Old 03-27-2002, 12:12 PM
FWK
Just can't leave it alone can you . Forrest
Old 03-27-2002, 12:17 PM
Sean's Avatar
just thinkin...
Sean is offline
Old 03-27-2002, 12:22 PM
Sean,
Just give it a good cleaning and have fun with it this season! Then next year put Whipples on them! Have you been sleeping on that boat yet? You gotta break it in you know.
Gary C is offline
Old 03-27-2002, 12:31 PM
While we are on the subject of the 420, does anyone have the details on these engines? Do they have steel cranks, forged pistons, 7/16 rods, rect port heads, etc. I have an opportunity to purchase 2 of these motors and don't know anything about them. I need a stocker for my Baja so I can sell it and step up to some sort of cat hull and use the motor I'm currently running. Not trying to muddy up the post, but as long as you guys are responding about pro charging a 420 I may as well ask about some of the specs. Thanks!
WETTE VETTE is offline
Old 03-27-2002, 12:53 PM
Charter Member #655
dyno's Avatar
I think the 420's are a better version of the 365 mag. forged bottom end rect. port heads roller rockers all the good stuff....
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 03-27-2002, 02:38 PM
CAT-DADDY
get a whipplecharger and you want have trouble later on.
Old 03-27-2002, 03:46 PM
NW_Jim's Avatar
Wette Vette - here are the links I posted elsewhere on the 420 specs.
Specs #1
Specs #2
NW_Jim is offline
Old 03-27-2002, 05:01 PM
Jim,
Thanks for the info. That motor looks like a great foundation for some big HP. I am no blower motor expert, but I feel if the heads can be worked a bit to lower the compression to 8:1 and the cam is changed to a blower grind, you would have a blower motor! The hard parts are good strong forged stuff capable of holding quite a bit of HP! I've got call this guy back and see if he still has the engines for sale. He claimed they are tired, but not damaged and he wanted $1500.00 for both or $800.00 each. Not bad if all of the parts are there.
Thanks,
Craig.
Old 03-27-2002, 06:37 PM
Biggus's Avatar
The 420 should make an excellent blower motor. As far as I remember the 525 Hawk was a 420 with a B+M 174 blower on it.
Soulds like a decent price as long as the blocks are not rotted out. A buddy of mine put a 420 in his 67 Camaro last summer!
Biggus is offline
First Gun
Swap Shop
1
09-11-2008 09:33 PM
MILD THUNDER
Northern Illinois Offshore Club
1
08-09-2005 01:31 PM
MILD THUNDER
07-28-2005 08:19 PM
LapseofReason
12-15-2004 09:00 PM
blown formula
32
11-20-2002 11:58 AM
Quick Reply: ProCharge a Merc 420?
