need help 6.2 merc
May I ask why you want to set the timing, Normaly you don't need to set it, And really you dont set them you just need to get it with in a certin range by pulling the cap off and lining up a few marks.
i just installed a new motor for a friend and like u said its close on the balancer but it wont move while moving the dist i new there was something about a wire to remove and ground
you do not use or need a timing light on this style engine with the crank/ cam sensor now. Do you have a manual from merc on this engine?
i dont have a manuel i mean its a pretty simple motor but the marks i wanted to match up at 0 and then set it wher it needed to be id say with it runnin now it is 8 to 10 degrees before and i didnt no if the compputer would relearn where it was or not from before or driving style starts and runs fine
