Will these swap???
Will these swap???
Sorry I don't have access to the prop talk section.
So I have SSM II's with 19 spline long shafts. Someone told me that they thought the II's could take Bravo props.
Can anyone confirm or deny this before I go ordering new stuff.
Thanks!
Thanks!
arneson-industries.com
Offshoreonly Advertiser
I can put the Bravo propeller onto your drive, however how you will address the difference in hub diameters is a harder one to solve.
The Speedmaster is a few inches less in diameter than the Bravo propeller is and thus there will be a lot of drag.
I make a propeller adapter that will allow you to put a new SSM#6 style propeller onto your drive which will be the more logical choice.
Rik
Arneson Surface Drives www.arneson-industries.com
Thanks.
Rik
Rik
They are limited to a 15" diameter + - a little and depending upon the boat, some of the smaller pitch ones (Pro ET) are only available in RH rotation with limited pitches.
