HELP!!!! What are these????
Ok so I have an 85 Chris Chraft Chris Cat with SSM II's. One of my steering rams started to leak, took it to a hydraulic shop to see if it could be fixed... Well now it leaks even worse! Can anyone tell me who makes this ram and if they are even still made or if there is a direct replacment for it.
Oh and this is not my boat pictured but its the same set up as I have.
RIPSTA Racing Team
Try to get us a better pic of the ram itself. Can't really see it in that pic. It's strange that it's painted black. They are usually S/S. What did the hyd. shop say or do? It should have been a simple fix. Their not that complicated a cylnder to rebuild. The paint might be covering some markings. There could be some scratches in the cylnder or on the piston rod that happens sometimes in which it would need to be replaced. You can pick them up sometimes here or on ebay for a couple hundred buck each. I'm not sure if Mercruiser offered an external steering set up from the factory back then with the TRS/SSMII. I'm guessing that someone added them aftermarket.
