Go Back   Offshoreonly.com > Technical > General Q & A
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 07-04-2009, 03:09 PM   #1
Distributor Gear
HELLO All,
Can you use a stock mercruiser distributor gear to drive a high volume oil pump and a crane 168741 cam. I know this person who just pulled the stock mercruiser distributor and the gear had alot of metal gone. Can this motor be saved by changing all the bearing or is it a complete waste, he had only 40 hours on it. Man this is a way to start the season.
alecsammy is offline   Reply With Quote
Old 07-05-2009, 02:51 AM   #2
32 Active Thunder
The stock dist gear is fine with a 741 cam and the pump is run by the dist shaft. Sounds like it wasn't mating correctly. Chances are the cam gear is toast as well.
Griff is online now   Reply With Quote
Sponsored Links
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
