Go Back   Offshoreonly.com > Technical > General Q & A
Register Upgrade/Renew Membership Forum Rules Search Today's Posts Mark Forums Read
OSO Sponsor
NorTech
OSO Sponsor
NorTech
Advertiser
Advertiser
Thread Tools Search this Thread
Old 07-08-2009, 04:18 PM   #1
1980 Wellcraft Scarab 377 twin turbo
Best location for an O2 sensor on a turbo EFI motor?
What is the best place to put a O2 sensor on an EFI motor with twin turbos? Before the turbo or after? The exhaust is a dry system. I found a special plate that goes between the manifold and the riser that is 1" thick and is drilled and tapped for the O2 sensor. The plate is made out of aluminum.
phughes69 is offline   Reply With Quote
Old 07-08-2009, 06:57 PM   #2
Sonic Booom II 31SS
Put the O2 in the downpipe of the turbo....not in front of the turbo.
niceguy is offline   Reply With Quote
Sponsored Links
Old 07-08-2009, 09:03 PM   #3
1994 Baja 236 500HP
OK, I am not familiar with Turbo systems. On my NA engine I have O2 bungs welded in the risers. I would think the AF readings would be more accurate before the Turbo. Again I am not a Turbo expert.
jeffswav is offline   Reply With Quote
Old 07-09-2009, 11:27 AM   #4
why is it better behind the turbo? Is in front of the turbo too hot for a wideband O2 or is it because of the damage that could happen to the turbo if part of the sensor breaks off?
Old 07-09-2009, 11:45 AM   #5
Sonic Booom II 31SS
O2 sensors don't like that much heat and don't like pressurization. I will get with my turbo guru if you'd like a more detailed explanation.
Search this Thread:
Advanced Search
vB code is On
Trackbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.6.8
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
Copyright 2008 OffShoreOnly. All rights reserved.
