Go Back   Offshoreonly.com > Technical > General Q & A
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 07-14-2009, 07:01 PM   #1
Procharger ?
I was wondering what the difference is in HP if you run a 5 lb pulley compared to a 3 lb pulley. Also wondering what the reliabilty factor is between the 2?
donzi-joey is offline   Reply With Quote
Old 07-14-2009, 09:23 PM   #2
Turbojack's Avatar
2003 Eliminator 30' Daytona
Depends on your engine starting HP. I am guessing it can make up to 100HP on some engines. Think of your engine as a bucket of water. The faster you tip it the faster you run out of water. Of course we could talking about years difference based on drivers.
Turbojack is offline   Reply With Quote
Sponsored Links
Old 07-14-2009, 09:44 PM   #3
GPM
DCB
GPM is offline   Reply With Quote
Old 07-16-2009, 05:10 PM   #4
sold it now looking
I had a Procharger. With mine I would've also had to remove cool fuel and add bigger injectors. more to it than just a pulley. Check on what the differences are between stage 1 & 2
steveh1209 is offline   Reply With Quote
Old 07-16-2009, 06:48 PM   #5
1991 Formula F242LS Procharged 502
on the older carb models the procharger tech guys told me they saw an average of 45% gain with the 5 lb kit . as far as reliability it all depends on how well you tune it and what package your putting on . My 502 had forged pistons good rods and steel crank and made it 11 years before loosing an exhaust valve . so thats pretty good longevity for the power it was producing on stock internals . now when i tore it down i put some srp blower pistons a set of extreme duty incolnel valves and a comp blower cam that they claimed helps produce better boost. with that done i see 7.5-8 lbs of boost with the same pully and feel i have an engine that will last me plenty long with the procharger on it. most important thing is watch your fuel ratio and timing, those can kill and engine quick .
MillershighLife is offline   Reply With Quote
Old 07-16-2009, 07:28 PM   #6
I am sending it to Mark at Precision in Louisiana, so I am pretty sure it will be tuned correctly.
Old 07-17-2009, 09:07 PM   #7
GPM
DCB
Quote:
So what do you think caused the increase in boost ?
Old 07-17-2009, 09:11 PM   #8
Pirate of the Chesapeake
Fenderjack's Avatar
32 Fountain Fever with a touch of Gellner/ 202 Chris Stinger
Quote:
A blower grind will be set up with a different lsa angle, durations then a cam setup for a NA app..
John jr
Fenderjack is offline   Reply With Quote
Old 07-17-2009, 09:28 PM   #9
GPM
DCB
less overlap, I guess that makes sense, thanks
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
