500-540 hp in a 24 outlaw sst 1996.. top speed and prop?
Had an engine built.. 500 to 540 hp in a 96 outlaw SST.
Bravo x drive. Sport tubes and open headers. does anyone know what speed I should be getting with this engine.. running Full MSD ignition. stock 96 454 thunderbolt fuel pump.
with a 26 4 blade was running 4500 to 4600 rpm.. max opperating range is 5200 rpms. was up around 70 mph.....
would a 25 3 blade mirage plus give me more speed and stability?
The Mirage+ won't give you more stability, and may in fact give you less, but it will also likely go faster since your X dimension is deep. You should be pulling 5,200 to 5,400 rpms with the right prop.
No reason that you shouldn't be able to spin the 26 faster with that HP. I spun a 24 bravo 1 to 5200 with 420hp in a 24 Outlaw.
A 25 Mirage plus will be better for top speed, but will suck out of the hole.
was running 300 hp thunderbolt at 53mph with a mirage plus 23 pitch at 4300 rpm...
we havent changed the jetting or advanced the timing yet though.. it is running a 850 HO holly double pump.. jetting is at 84 in both primary and secondary and max timing is set at 34...
