Engine alarm >
Engine alarm
Engine alarm
Old 08-17-2009, 08:49 PM
Default Engine alarm
35 Outlaw with 525's. Port motor set an alarm after hitting a pretty big wake Saturday. Steady alarm, the engine would not rev over 1500 rpm's. I shut off the engine and restarted. It ran fine until I hit a wake again. This happened three times coming home. I pretty sure it's a sensor. Hopping it gets looked at this week. That code should stay in the computer, right? Any ideas?
redbud35 is offline
Old 08-18-2009, 12:47 AM
Check in fault history as well as active faults. From your description, it could be a simple loose connection but it's going into guardian mode so it's one of the critical ones most likely.
Should be a relatively easy thing to figure out. Theory in a post is always easier than fixing it.
SDFever is offline
Old 08-18-2009, 11:39 AM
i would guess water pressure sensor...its at the back of the engine,,,,its screwed into the power steering cooler,,,easy to get to,,,let us know what you find,,,also what lowers where you thinking about putting on???
TWIN-SPINS is offline
Old 08-18-2009, 12:17 PM
To my understanding, the only things that trigger the dash alarm are the oil pressure sender, the drive lube monitor sensor, and the H2O temp sensor.... that should narrow down what to look for.
eichhoma is offline
Old 08-18-2009, 03:08 PM
That does make alot of sense. But I think eichhoma is correct. I have CPR looking into it. It As for as the lowers. I would like to try a pair of shorties. Just don't want to spend a bunch of money and not be able to use them. runs great until you hit a rough patch of water.
redbud35 is offline
Old 08-18-2009, 03:12 PM
Scott will hook you up right over there!
I just went through changing out all my senders and switch's... learned a lot... learned (according to merc's wiring diagram) that those are the only three sensors that go to the engine alarm.... Let me know if you need a hand, I am always down for a beer and helping out a fellow boater. I'll be down tomorrow afternoon through the weekend. Mark
eichhoma is offline
Old 08-18-2009, 04:04 PM
pm sent
redbud35 is offline
Old 08-18-2009, 08:35 PM
I have found that 496,500efi and 525efi will give you an alarm for man.temp.,IAC,etc. not just the usual three.
speedreeder is offline
Old 08-18-2009, 09:04 PM
iam getting code 179,160,, both exhaust manifolds overheating at a 1000 rpm,,,just above idle cruising,,,,what would cause this,,,i need to start somewhere,,i think its either blockage,,,or raw water pump,,,never get alarm while running on plane,,,need some help guys 496 h.o. with stainless marine,,,other engine does not set alarms
Old 08-19-2009, 07:32 AM
Good information.... thanks! mine is not an efi - has no computer. So I am guessing the efi's potentially have other triggers that go to the alarm as well. I will check my manual, it shows diagrams for all their engines. My merc manual (for mine - the 525SC) just shows the three I stated above as the only alarm triggers....
eichhoma is offline
