496 knocking noise
496 knocking noise
2003 496 mag with bravo drive,got a knocking noise around 4000rpm.Iam a gm tech so I know what a rod knock sounds like,this not the same noise,It almost sounds like your anghor is at the bottom of the bilge bounching around,engine runs great with good oil pressure,plenty off power so the knock sensor is not picking up any sound and not retarding timing.try it with the silent choice on and off knocking noise is there at around 4000rpm both ways so I dont think its a exhaust shutter,there is also no rethum to the noise
I can take over 4000rpm in neutral and it wont do it,the boat comes out of the water good so i dont think its the outdrive,
any ideas?Im lost.
thanks.
any ideas?Im lost.
thanks.
1 Post
mrfixxall
2003 496 mag with bravo drive,got a knocking noise around 4000rpm.Iam a gm tech so I know what a rod knock sounds like,this not the same noise,It almost sounds like your anghor is at the bottom of the bilge bounching around,engine runs great with good oil pressure,plenty off power so the knock sensor is not picking up any sound and not retarding timing.try it with the silent choice on and off knocking noise is there at around 4000rpm both ways so I dont think its a exhaust shutter,there is also no retham to the noise
any ideas?Im lost.
thanks.
any ideas?Im lost.
thanks.
