Quote:
Originally Posted by PatriYacht
Baltek has a product they call Decolite. It's end grain balsa covered by a thin layer of fiberglass on each side. Looks like a sheet of plywood and comes in different thicknesses. I would rib anything that needs any strength.
BINGO JUST saw this Mrv8outboard and myself replaced my motor cover in 95 or 96. used 1 sheet of DECOLITE cut off the extra and used it for the turn down in front and did ribs with balance also cut and glassed in a pro stock scoop primed it with a heavy primer filler to seal the ends lots of sanding so it looked one piece and you could jump on it .I DID NOT USE THE UNDER LINER that was made out of glass
its weigth was hugh. so my hatch weights about 30 lbs to attach it I use just to latches that have a pin going threw them so no more loose hatch, and you can keep the elecrtric piston. for a back seat I got rid of the slant piece just made it 90 degree did the base to. then paint make sure you get 1'' what I would do different is dig out a 1/2'' of balsa all around the edges and fill with resin and fg filler re sand that way water can't get in the core ever after 10yrs I had a spot on the corners
any other questons artieps in the baja sec look under pics of my boat you can see the scoop.
