#6 steering problem
Hello everybody - I am new to OSO and could really use some help.
I am installing a new set of #6 drives, single hi-volume power steering pump, dual filters (hi-pressure and low-pressure), std char-lynn helm.
1st question: drive hose routing can be two ways and I do not know which is correct. Left and Right hoses from helm to drives can either tee and go to each drive, or can run hoses in series (ie. L hose to stbd drive left, stbd drive right to port drive left, port drive right back to helm)
2nd question: when running pump, steering wheel stays still until slight pressure is applied, then it starts turning by itself all the way to stop. Does the helm have a valve that could be sticking? I have not tried this with the cap off the resevoir - could the system not be venting properly and the pressure is turning the helm?
Thx for any suggestions!
