valve cover vents on a  502 EFI Gen V >
Old 09-22-2009, 04:34 PM
Default valve cover vents on a 502 EFI Gen V
Where do the valve cover vents connect on a 502 Efi gen V
The vents connect together with a hose from the 2 valve covers.
But where does that connect after,
There is nothing on the intake plenum
Do i need a PVC valve, or a breather?
there is a lot of fumes and oil coming out of there
Some one told me that is should connect to the throttle body
but the only fitting there is the one for the hose from mechanical fuel pump
thank you
Matys is offline
Old 09-22-2009, 09:24 PM
Charter Member #1171
obnoxus's Avatar
goes to the flame arrestor
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 09-23-2009, 01:07 AM
Received 1,816 Likes on 904 Posts
Thats where mine go, but mines a Gen VI
Griff is offline
Old 09-23-2009, 06:08 AM
flame arrestor on my 502 efi is silver mesh, and its empty inside, there is no fitting anywhere,
on one of the Merc parts website, i found a pic of this
does that go inside the silver mesh flame arrestor , or is used
instead of the silver mesh flame arrestor.
so is that where the Valve cover vent hose connect to?
thank you
Matys is offline
Old 09-23-2009, 08:05 AM
obnoxus's Avatar
see the fitting on the left side,,,,, thats where it goes
obnoxus is offline
Old 09-23-2009, 10:13 AM
Default mrfixxall
thank you
like everyone stated,its on the bottom of the flame arrestor..its a half moon tab that is riveted on the bottom and the hose slides over it exposing the upped half..
FIXX is offline
Old 09-23-2009, 12:49 PM
thank you
That IS the Merc Flame arrestor. You may have an aftermarket one that doesn't have the fitting.
Griff is offline
Old 09-24-2009, 01:21 PM
what would you do if you were running a K&N with no connector ?
Laktrash is offline
Old 09-24-2009, 01:40 PM
Default mrfixxall
switch back to the factory merc one with the proper hook up or call K&N and see if they have the one for your set up..
FIXX is offline
Old 09-24-2009, 02:35 PM
Ken N's Avatar
Arrow K N arrestor
I have a K N arrestor on my 502 MPI , i drilled and taped the collar and installed a fitting.
Ken N is offline
