Quote:
Originally Posted by Sport 280
I am replacing my Mark IV hp400s with 550 horse Gen VI 502s. What fuel flow rate and pressure should an electric fuel pump have for these engines running holley carb and dart intake on Dart pro I heads?
Thanks for the help.
Fred
Without getting to complicating the formula your looking for is for Brake Specific Fuel Consumption(BSFC), the lower the number the more efficent an engine. When you build a fuel system for a N/A motor .55 is a good number, a blower motor go up to .65. A properly tuned N/A engine will probabally come in @ .45 to .5 on a dyno.
BSFC x HP= LB of fuel and HR. .55 x 550hp= 302.5 lbs of gas an hr. Gas weighs around 6.5lbs a gallon. 302.5/6.5=46.5 gallons an hr. So any electric pump rated for more then 50gph will work.
A Holley blue pump will probabally work fine, but not get cooled by airflow like it would on a car. Aeromotives A1000 pump is rated the same as a blue pump, but cooled by the fuel flowing thru it. It also costs twice as much. 6 to 8 psi at the carb is fine.
Very important as well. An electric pump doesnt flow well or make proper pressure if it has a check ball/ check valve in front of it. So if your boat has one, remove it. It will be located at or near the fuel tanks pick up. Also mount it as low as possible in the bilge.
LE
