Go Back   Offshoreonly.com > Technical > General Q & A
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 11-06-2009, 03:31 PM   #1
700 SCi Question
Hi All,
Quick question about the Merc Racing 700 SCi. For a motor that was run through an NXT, are there any changes that have to be made to hook one with a Bravo XR setup (coupler, rear motor mount, other)?
Many thanks,
Yoryi
ykoutsaris is offline   Reply With Quote
Old 11-06-2009, 03:46 PM   #2
Fixx
Quote:
Originally Posted by ykoutsaris View Post
Hi All,
Many thanks,
Yoryi
i think you also have to buy a special wire harness and or adaptors to work with your analog gauges..i believe its a smart craft wiring set up..Everything from your xr set up should work, you may need a h/d coupler tho.
mrfixxall is offline   Reply With Quote
Sponsored Links
Old 11-06-2009, 04:39 PM   #3
Offshoreonly Advertiser
Young Performance's Avatar
I thought the 700 had a different bell housing and coupler than the XR.
True, Custom EFI and Carb. engines from 500 to 1500 HP. Also specializing in outdrive upgrades and repair, custom rigging and fabrication, we can handle all of your performance boating needs. See our entire engine line at www.YoungPerformanceMarine.com Contact us at 615-216-7449 or youngperformance@comcast.net
Young Performance is offline   Reply With Quote
Old 11-09-2009, 09:36 AM   #4
Thanks for posting guys... the bell housing looks different in the pictures I saw, but hard to tell for sure... I guess I'll have to check in with Merc to be sure.
Yoryi
Old 11-09-2009, 11:25 PM   #5
I'm guessing you would need to do something with the "PCM" also to match the drive set up also, Kind of like you would need to do with a alpha veres bravo drive.
Boat Tech is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
