| OSO Sponsor |
| OSO Sponsor |
11-06-2009, 09:30 PM
scarab98
2004 37' Active Thunder
myco trailer
What is the best hub seal .Getting some water in hub.Are the $30 dollar seals from myco the best way to go.
11-07-2009, 03:40 PM
mrfixx
Quote:
Look on the inner lip of the seal, get the part # and have your local auto parts store cross reference the seal.Inspect the spindle for seal cut or grooves where the axle rides,if their are seal cut grooves then you will need a speedy sleeve that slides over the spindle surface where the seal rides..its held on with loctight.. just make sure the seal has a double lip,most seals are made by skf (CR chicago rawhide)or national.
11-07-2009, 04:42 PM
Rob
Hustler 388
depends on which seal there using, thieve changed a few times. My 2001 has a special seal,that I couldn't find any were else,I searched all the mfg.Mine has a stainless race/sleeve that the seal rides on.if your on the side of the road if your haven't bought spares you'll have to take off the sleeve and put a regular seal on it. I'm thinking its a double lip seal.I have pictures I just redid all mine brakes and every thing,so I have a spare hub,bearing seals sleeve and brake lines,
Ill did up the picks and see if i have the #'s I think It was Chicago rawhide that was making the seal for Myco.
11-07-2009, 11:22 PM
Ginger or Mary Ann?
1999 32 Fountain Fever, 1995 Baja 29' Cruiser
Do you have the rubber plugs in the dustcap? Mine last for 2 yrs max then are usually dried and split. And this is only from the annual 200 miles beginning and end of boating season towing.
11-08-2009, 07:58 PM
scarab98
Thanks guys ,Looked at spindles real close grooves in spindles going to find some speedy sleeves.I have new double lip seal already Just wanted to make sure i didn't need to put the $30 dollar seals back in.And have all new rubber dust caps.
11-08-2009, 08:41 PM
Ginger or Mary Ann?
Just don't drive the seals in as deep. New meat.
11-08-2009, 09:37 PM
scarab98
I will look at them again to see if that will work.I think there is some pits.
11-08-2009, 11:12 PM
Speedy sleeve the spindals,they will make a tighter seal,make sure you pack the seals between the 2 lips,this will make the seal last longer,i have 10 yrs on mine and havnt touch them yet!
11-09-2009, 02:37 AM
Rob
Hustler 388
new style for the stainless sleave
11-09-2009, 02:50 AM
Rob
Hustler 388
remember this ,the caliper slider.that slides in a rubber tube in the caliper, the rust will build up on the back side of the rubber that between the rubber sleeve and the calipers housing,see picks,what happen is the caliper Will not side back and forth,so it sticks,it will make the pads wear uneven,crooked,i cleaned it all up ,polished the sliders to chrome finish,stainless? greased it ,seems to be OK so far,it needed all new pads and had the rotors turned,2001 myco
Also on the model 20 actuator has a new designs shock absorber, ya don't get the banging any more.
hope this helps
Rob
