Go Back   Offshoreonly.com > Technical > General Q & A
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 11-07-2009, 09:55 AM   #1
32 thunder rick
rssteiny's Avatar
2000 32 active thunder
blower/ pro charger
who makes a small blower/ procharger with 3-5 lbs boost max want to stay turn key on my 500hps with minamal boost. have very little height clearance. whats better blower or pro charger/ whipple.
rssteiny is offline   Reply With Quote
Old 11-07-2009, 09:59 AM   #2
jfm
25' Tug
Turn key.... that is funny. I ran a side mount 2.3l whipple. It was ok for me but took some tuning and staying on top of. Also very rough on the drives if you aren't careful
jfm is offline   Reply With Quote
Sponsored Links
Old 11-07-2009, 10:10 AM   #3
32 thunder rick
rssteiny's Avatar
Quote:
I would think 3lbs boost would be turn key, set up properly.
Old 11-07-2009, 10:12 AM   #4
32 thunder rick
rssteiny's Avatar
Im diong my bottom ends this winter would i be better opff to make them 540s and stay natural im at appx 575 hp now. looking to get to 650 hp.
Old 11-07-2009, 11:26 AM   #5
Offshoreonly Advertiser
Young Performance's Avatar
Yes, I think you would be better off building a larger NA engine if you only want 650 hp. Take your current setup to 540, 547, or 555 cu in and you will easily make 650+ hp. It will be a much simplier set-up over the sc. Now I think superchargers are great, but not in your situation. You could probably do the larger NA engine cheaper than a good sc set-up. It is definitely the way to go if you were planning on doing the bottom end anyway. Give me a shout if I can help.
Eddie
True, Custom EFI and Carb. engines from 500 to 1500 HP. Also specializing in outdrive upgrades and repair, custom rigging and fabrication, we can handle all of your performance boating needs. See our entire engine line at www.YoungPerformanceMarine.com Contact us at 615-216-7449 or youngperformance@comcast.net
Young Performance is offline   Reply With Quote
Old 11-07-2009, 11:37 AM   #6
32 thunder rick
rssteiny's Avatar
Quote:
Eddie
Thanks eddie ill keep you in mind when i get started.
Old 11-07-2009, 11:42 AM   #7
causin trouble's Avatar
01 353 Fastech
procharger
3-5 lb boost will run fine call Dean at Gellners 216 398 8500
causin trouble is offline   Reply With Quote
Old 11-07-2009, 05:20 PM   #8
32 Active Thunder
I would stroke them to 540's before even considering procharging them.
Griff is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
