Quote:
Originally Posted by Biggus
He also mentioned high rpm cold starts can cause upper valve train wear as the components are rubbing together with mimimal lubrication until the oil makes its way to the top end.
Kurt
Kurt, that is the one thing I've never really liked about the new EFI's like the 525/600/700sci... You crank it over, it fires and immediately goes to 1500-2000 rpms and slowly settles down... When I fire up I try to keep it at or around idle (as much as my carbs allow without stalling) and once I see oil pressure I'll raise it up to 1200 until it's warm and driveable.
I just did a tear-down for one of my engines for a 250 hr refresh and everything internally was perrrrfect.
