Go Back   Offshoreonly.com > Technical > General Q & A
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 11-21-2009, 08:09 PM   #1
2003 Sonic 31ss w/ 575's
575sci Head service
Looking for info on the 300 hour head service... the hubby is curious what other people are doing... valve seals, springs? Or complete new valvetrain... any ideas?
SonicBunny is offline   Reply With Quote
Old 11-21-2009, 10:02 PM   #2
I hate the winter!!
Vinny P's Avatar
99 checkmate 259
I rebuilt a pair of 575SC's last winter with about 300 hours or so. I planned on replacing the springs, upgrade to 10* Titanium retainers and 10* locks. The surprise was the valves were starting to tulip, so ended up replacing all the valves. Before Crane went out of business, ended up replacing all the rockers as well.
Vinny P is offline   Reply With Quote
Sponsored Links
Old 11-21-2009, 11:48 PM   #3
Offshoreonly Advertiser
Young Performance's Avatar
At a minimum. replace the springs, retainers and locks(10* steel) and seals. I don't see a need to go to titanium retainers. The problem is the market is flooded with cheap import titanium retainers for around $200.Good titanium retainers will run $300+. You just won't see any benefit in a 575. It's just not worth the money. As far as the valves, that depends on how they look. As Vinny said, he replaced his because they were on their way out. Just wait to see what they look like. Hope this helps.
Eddie
True, Custom EFI and Carb. engines from 500 to 1500 HP. Also specializing in outdrive upgrades and repair, custom rigging and fabrication, we can handle all of your performance boating needs. See our entire engine line at www.YoungPerformanceMarine.com Contact us at 615-216-7449 or youngperformance@comcast.net
Young Performance is offline   Reply With Quote
Old 11-22-2009, 01:49 AM   #4
32 Active Thunder
What needs to be done will be determined after the heads come off and everything is checked. Minimum would be valve job, seals, springs and retainers.
Griff is offline   Reply With Quote
Old 11-22-2009, 06:43 AM   #5
I hate the winter!!
Vinny P's Avatar
99 checkmate 259
Eddie,
I agree, Titanium retainers on a hydraulic cam are not needed. However, after spending soooo much money on rebuilding everything else, I figured why not get Titanium. In any case, 10* locks are definately a good thing to add. Personally, I dont see why Merc ever used 7* locks.
Old 11-22-2009, 07:26 AM   #6
Thanks all for the info... thats what we are planning to do... plus blower service since they will be coming off... BTW, which are the better blowers...weiand or Holly? Our has holley stamped on the rear casing...
Old 11-22-2009, 12:01 PM   #7
1998 Ultimate Warlock 25'sxt cat
both are made by the Holley corp. now, only diff. is the holley
(B&M) HAS teflon stripped rotors, while the othert doesn't.
blownjet 468 is offline   Reply With Quote
Old 11-22-2009, 12:04 PM   #8
99 sr24 htm
sonicbunny the blower on the starboard side was just rebuilt by the blower shop before he lost the boat.
dennis r is offline   Reply With Quote
Old 11-22-2009, 12:24 PM   #9
2001 Profile 280 CAT
The earlier 575s had Wieands, which were slightly better than the B&M version. The difference being front and rear oil bath bearings. Only the front bearings are oil bath and the rear bearings are sealed on the B&M. Either way the bearings are prone to fail.
JRider is offline   Reply With Quote
Old 11-22-2009, 06:15 PM   #10
Quote:
Originally Posted by Vinny P View Post
Eddie,
I could not agree more. You will never find 7* retainers in my shop. The point I was trying to make about the titanium retainers is to watch the imports. There are some cheap ones out there. It definitely can not hurt to go to titanium over steel, that's for sure.
Eddie
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
