Factory rods BBC
You can never have overkill on rods or crank. Don't skimp and get Eagle H Beams--> They will stick through the block just like a stock rod if not easier. my bilge pump pumped more oil than it did water when we used Eagles rods, and the sound of a rod breaking at 5500+ rpm is interesting, and expensive, get the good sh*t, it'll last through several motors.
I'd be interested in your rods but my pistons are press fit and I don't want to replace the pistons. Is there a way to convert either that is friendly on the wallet?
1 Post
Fixx
impossible,the rods have a bushing in them and press fit don't,..look for a good set of I beam or dimple rods with arp rod bolts,just make sure you prestretch the rod bolts before assembly.
If you are planning turning over 6k in your boat, don't worry about those rods so much, we have drag raced 3/8 std chevy B/B rods in several engines with many many runs spinning them to 65-6800 all the time, never a issue. What you need to concern your self is the drive....that will fail first at that RPM, my advice is to set the engine to operate at a max or 55-5700, things will work much better...Rob
1 Post
Fixx
Spend the extra coin on the arp 2000 rod bolts..My friend chris @ nelson's racing engines in fl uses k1 rods all the time and never had any issues..supposedly merc 525's have the h beam style k1's in them..so I'm told.
Geronimo36
a friend ran his stock GM rods to 6K rpms for several seasons without any issues but I seem to remember 5800 is about max for them. After he sold the boat I think a rod let go so it's pushin it!
