Go Back   Offshoreonly.com > Technical > General Q & A
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 12-14-2009, 10:39 AM   #1
Bravo prop's?
New to the performance boating thing. Do Bravo prop's fit on Imco drives? Specifically Imco SC?
X-rated is offline   Reply With Quote
Old 12-14-2009, 11:46 AM   #2
JasonSmith's Avatar
1999 Baja 29' Outlaw
Yes, as long as the propeller has the correct size insert.
JasonSmith is offline   Reply With Quote
Sponsored Links
Old 12-14-2009, 03:09 PM   #3
32 Active Thunder
A lot of the parts in the Imco are just Merc parts. Not sure about the prop shaft, but they are the same size and splined the same as the Merc Bravo. There are 2 different size diameter prop shafts used in Merc Bravo drives. You just need the correct prop hub kit.
Griff is offline   Reply With Quote
Old 12-14-2009, 08:34 PM   #4
Thanks, So would you say the Bravo XR is the same drive as an Imco SC? How much power will a SC handle?
Old 12-14-2009, 08:39 PM   #5
JasonSmith's Avatar
Quote:
Same gears, same bearings, seals, races. The only diff is the shafts & cases.
As far as how much they will handle??? They break.
Old 12-14-2009, 09:52 PM   #6
32 Active Thunder
Jason Smith can tell you how much HP it takes to break them regularly
I ran an Imco SC upper behind 550hp in a 5500# boat for almost 300hrs and never had a failure.
Old 12-14-2009, 10:02 PM   #7
2005 Kryptonite 29
I have a customer with a Teague platinum upper and IMCO SC lower 850 blown HP, the lower lasted just under 50 hours the upper is still holding strong @ about 70 hours 4500# boat run hard. I have the same boat just a few years newer with about 600 hp, not run so hard. It has the IMCO Extreme SC upper and lower 90 hours still holding strong.
DonRoc is offline   Reply With Quote
Old 12-16-2009, 12:52 AM   #8
JasonSmith's Avatar
Quote:
Jeff ran 900+ through them before I got them.
I've only broken one side 3 times. I think after it ran out of oil the 1st break there was something just not right about the case.
I've got a new upper case now so we'll see how 2010 treats me.
Old 12-16-2009, 02:05 AM   #9
32 Active Thunder
I didn't even realize that your drives were Jeff's old ones. Hopefully 2010 will be better. I heard you had issues before the MWBP Poker Run, but figured you got them all worked out before you ran in the Shootout.
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
