Holley Vs Demon?
Are we going to see you around this year Mark? A little upgrading will be nice but we still won't be keeping up with you.
You have any input on the carb debate? We're trying to decide if it's worth spending the extra cash to get a custom set up carb from a place like nickerson or to save a little and just get something off the shelf.
as far as off the shelf holley has a 950 blower spec carb, but I to suggest patrick at pro systems, for about what a new holley cost he will dial you right in....I run his stuff on my top sportsman race car..Rob
Well I ordered my new carbs from Patrick at Pro Systems on Wednesday. He had a good price compared to the other guys with what sounds like the same level of customization and quality as the other guys who were about $280 more per carb. Plus he is located only about an hour and a half away, which for some reason makes me feel more comfortable.
For only a couple bucks more than off the shelf stuff it seemed like a no brainer.
How big is your budget?
dAMBEST Billet 4500 Carburetor Update
Hi Everyone!
Sometimes progress is so fast we don't even get time for photos! Our billet 4500 shown below now sports a new primary bracket with a better angle and the secondary bracket can be progressive or 1:1. Plus the whole throttle assembley is now electrolised nickle plated.
We've been shipping the new 2.375" butterfly 4500's. With a wet flow of 1633 CFM at 17" and dry flow over 1800 CFM at 20", these are meant for single four barrel, tunnel ram manifold engines that make from 1000 to 1400HP. Perfect for Top Sportsman, Top Dragster, Truck pull, mud bogger or anywhere where power and throttle response are both a must. Pictures just don't do this awesome carburetor justice. We also have new linkage brackets for two four barrel applications.
We recently developed a NHRA Pro Stock upgrade for Braswell and Holley Carbs. We bring their casting's into our technology, with amazing results.
John
3/4 view
Side view, with standard air cleaner height. Can be ordered with raised air cleaner rib for improved air flow.
Top View, showing latest booster assemblies. 34" of booster signal at 10" draw on carb, Wow!!!!!!!!!!!!
Wet flow pictures to follow.
dAMBEST Billet 4500 Series Carb Pairs
Venturi Butterfly Booster CFM at 10" water CFM at 20" water Wet CFM at 17" water HP Range Price USD
1.575" 1.750" Skirted 1894 2658 1600 750-1100 $3,798.00
1.700" 1.875" Bottom / Shear 2100 2912 1904 775-1150 $3,798.00
1.825" 2.000" Bottom / Shear 2400 3184 2128 800-1200 $3,798.00
1.950" 2.125" Bottom / Shear TBA 3364 2612 900-1400 $3,798.00
2.090" 2.250" Bottom / Shear TBA TBA 2840 950-1500 $3,998.00
2.090" 2.375" Bottom / Shear TBA TBA 3266 1000-1800 $3,998.00
Hi Everyone!
John
3/4 view
