Shift bracket wire question.
1) non insulated butt connector
2) "light" crimp both wire ends with your stripped wire conductors (core)
3) solder both ends - no cold solder joints either
4) apply (this is done before you crimp your connector ends) a dual wall shrink tube. Heat and shrink into place
5) Done. You have now the best budget boater electrical connection for your marine application
Thanks I will sure check that. I just got the boat.Still cleaning and checking stuff.
