water pressure question-extra pressure blow off >
Old 01-23-2010, 08:07 PM
Brotherhood #1
Sick Stinger's Avatar
Default water pressure question-extra pressure blow off
Quick question, for the water pressure blow off i was told before the strainer is where you would want it. Anyway on my engine its located on top of the ware outlet housing. Should i keep it there or put it just before the inlet side of the strainer
-Mike
Sick Stinger is offline
Old 01-24-2010, 07:47 AM
PAST DUE's Avatar
my engine builder says put relief valve at the very top of motor (t-stat housing) so you don't rob the engine of water.
PAST DUE is offline
Old 01-24-2010, 08:33 AM
Brotherhood #1
Thanks answered my question, thats where it is.
-Mike
Old 01-24-2010, 12:35 PM
You may not even need it. I install them in the strainer to stop the pressure spikes when the boat comes in and out of the water. Those spikes really don't make it past the water pump and into the engine. If your water pressure is not to high, then you really have no need for the relief valve.
Eddie
Young Performance is offline
Old 01-25-2010, 02:57 PM
RIPSTA Racing Team
fireboatpilot's Avatar
Mines in the strainer also. Like young said, the pressure spikes when you splash down won't make it past the pump but it could blow the seal out of the strainer lid. Been there done that. Putting it after the pump won't prevent that from happening. Your not going to get enough pressure from the pump to ever blow the relief, it's open to the exhaust after stat is open, providing you run one.
fireboatpilot is offline
Old 03-17-2010, 12:10 PM
i talked to mercury racing,,,they told me to install it after the water pump,,its suppose to protect the engine from blowing hoes off,,,said it shouldnt get over 30psi,,,,he gave me a part number from mercury marine accesory catalog 863208A3,,,my engine is a 496 h.o.,,,
TWIN-SPINS is offline
