How to get to 80 mph with a single screw
93 octane. I run 9.5:1 with hypereutectic pistons and up to 6.2psi with no problem, although I do have alum heads. Thats why I said 9.0. I would not go over 6psi with the 9.0 though. Not sure what the stock 525scs had for psi. The problem is the blower is a might small for a 454 and the higher compression helps a great deal and allows one to keep the blower rpm down so as not to make too much heat. Its a real good move with the 177 on a 454.
A smaller top pulley on the blower and a BBlades labbed prop should get you there. No need to change the Tstat. Teague used to stock the 8# pulley which is about 2.75". You can still run 92 octane fuel and don't have to change anything else except for maybe the SC belt. Thats about all you can do without going inside the engine or adding a chiller.
Valako's comes out around 8 HP/MPH I think? I think the 525SC is over rated slightly also. Based on those numbers it would put this boat with a 525 at around 66 MPH. Never know maybe Reggie slipped a couple out with super sonic space age materials.
It took my 93 27' Fountain about 650 hp to get to 80. And, that was doing nothing with the prop of drive height. But, I agree that if you are running 76 gps with 525, that pretty good.
Im surprised this didn't come up earlier. Yes it was 76mph on the GPS. Its a great running little boat. Im a pretty big fan of the 525SC but will give most of the credit to the hull design.
