Swap GEN6 to Gen4 454 flywheel and housing?
Can you swap a Gen 6 454 flywheel and housing onto a Gen 4 454? Are there any balanciing issues?
Will a Gen6 502 also fit onto a Gen4 454?
I don't think there is any issues with the bell housings,but I believe the weight on the flywheels is different.Has something to do with the gen 6 being 1 piece rear main and the gen 4 is 2 piece.
Premature bearing wear? I did it and it shook the boat to bits at idle.That was when Gen V's had just come out in a Chris Craft Stinger 222.It shook the thing on the trailer that bad.I would be able to tell you the part number you need if a buddy of mine would return my book,if you read this John.Kind of like breaking a blade off a 3 blade fan.
Charter Member #601
Forumla.. the bellhousing will fit.. the fly will fit also, but as it has been mentioned.. the fly has a differnt counter weight from gen IV to gen V and VI..
Go to your chevy dealer and but a flywheel for the Gen IV.. very resonalble, compared to Merc.
I had one of the first 502 short blocks out of the factory and chased the flywheel thing, but reused my bellhousing from my 1988 Gen IV motor..
Dick
Dick
