Go Back   Offshoreonly.com > Technical > General Q & A
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 04-21-2002, 07:44 PM   #1
30' Shadow Cat
Oil pressure guage
My oil pressure guages do not work.The engines produce great pressure,I hooked up a mechanical to make sure.Is there any way to test the guage and make sure that it is not wiring.I have new sending units.The guages are pegged high with no power.When power is applied they go to zero and stay there with the engines running.If they are bad does anybody know where I can send them to get fixed.They are older VDO and would hate to replace all the guages because I am sure that they do not make that style anymore.
Fishead
fishead is offline   Reply With Quote
Old 04-21-2002, 07:56 PM   #2
Tinkerer's Avatar
1992--34 SCARAB
Smile
Have you ever pulled the motor? Is their a chance that you have the guage wire on the low oil sender. The low oil sender is the small one. The big one is the guage sender.
Tinkerer is offline   Reply With Quote
Sponsored Links
Old 04-21-2002, 07:58 PM   #3
speel chekk this fokker!
puder's Avatar
27' Scarab
i am 90% sure i am redoing all my guages with gaffrig. If so you can have my old VDO OIL psi gauage cheap.
Pardon me, while I whip this out!
puder is offline   Reply With Quote
Old 04-21-2002, 09:10 PM   #4
blue thunder's Avatar
330 Carver 30' Scarab Panther 17' ProV Lund
You have the wrong sender for VDO. You probably have mercruise senders. They will do exacty what you describe. I just switched from vdo guages to gaffriges. Didn't change the senders and they didn't work. I also have the vdo senders that are yours for the cost of freight. I now have the gaffrig senders and all is good. vdo has the voltage reference backward to Merc and most senders we see.
BT
blue thunder is offline   Reply With Quote
Old 04-22-2002, 07:01 PM   #5
30' Shadow Cat
Blue Thunder,
I will take the senders and send you mine that are new as backups if you like.email me your address and I will set up the Fedex shipping from my end.I will send you a filled out airway bill.email me at fisherm93@aol.com or call me at 770-920-1444
Old 04-22-2002, 09:03 PM   #6
My plessure. check your email.
BT
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Red Light In Center Of Oil Pressure Guage Flicks On ActiveFun General Q & A 1 07-31-2006 10:16 PM
Help me read my oil pressure guage FlyFast General Q & A 3 07-31-2004 12:58 AM
oil pressure guage flickering from normal to pinned, then back Rambunctious General Q & A 5 07-08-2003 02:21 PM
water pressure guage scottsumrall General Q & A 16 08-21-2002 12:26 AM
Oil Pressure Guage Malfuntion? Allan4 General Q & A 4 06-27-2002 06:41 PM
Search Engine Optimization by vBSEO 3.2.0
