engine cuts out momentarily when hitting hard waves...
1 Post
Well back to the drawing board. The cutting out is getting worse and worse (doing it more frequently with more delay now). I have adjusted floats, cleaned and checked for pinfit on main lug, check all fuel lines.
Wonder if its the Thunderbolt? I eyeballed the gauges as I was going through a series of rollers and it cut out twice for about half a second each and the only gauge to falter is the RPM, it will drop almost completely to zero then back to RPM.
New scenario now, the engine will cut out on clean smooth water, just out of no where cuts out then comes back.
We had a the same issue. It was a cracked ground wire connection inside the Merc wiring harness about 6-12 " from the main plug. We would hit a wave and it would miss. We finally found it by moving all the wiring around until you hear the miss. Finding the bad connection/loose or cracked wire, etc. is not easy...it took us two years to find it!
I had same exact problem last year but my motor is efi,would cut out on big waves,finally found one of the wires in the harness that was bad internally,found it by accident when checking the timing. I bumped a wrench against a ignition wire behind the motor idling and it quit,I had wiggled all of them several times before but just got lucky and finally hit it just right,Smitty
