AN Fittings (where to purchase)
The hose/line aboves description is Insta Grip 300 PSI, W.P. 3/4. I bought it off the board listed as -12 AN hose??? Just not sure if the hose and fittings are meant for each other. The hose appears to be what you'd use for water/heater application.
Thanks for the help. Also is it necessary to have stainless lines when using AN style fittings?
Are the 180 deg fittings above are for Push Loc or Twist Tite???
Thanks,
John
Thanks,
John
the rubber hose doesn't chew thru everything it touches either. for flow and performance they are exactly the same.
no. the stainless is only one type of hose and the "pushlock" aeroquip does everything that the stainless does. you need the stainless when the the interior is teflon for extremely hi presure applications. for oil and fuel, the push lock non stainless has a lot of benefits over the stainless except for appearence.
PM sent.
John
