502 Oil filter questions w/HP500 oil Thermostat.
Have gen 6 502 mag carb that I just installed a HP500 Oil Thermostate because my oil temps were way too low. have the center bypass valve removed in filter boss on block and the changes the outer one to the 30psi.
Which filter do i want the wix/napa 1061 or the 1060 Any advantage to the 1060 having the antidrain back and i think it also has the bypass in it.........Before the hp oil thermostat i have been running a 1061.
