Carb size
Old 06-15-2010, 08:25 AM
Nordicflame's Avatar
See my post here about gains with a 4150 to Dom conversion...
Go with the Dominator...
http://www.offshoreonly.com/forums/n...y-results.html
Nordicflame is offline
Old 06-15-2010, 09:15 AM
Originally Posted by tinman565
ok...my buddy wants an opinion on carb size. Just a general estimate. Shooting for 700hp with dart heads (steel), (big block). I said a Holley 950 HP double pumper. Your opinions please ? Thanks.
My best bud has a #9022 Holley 800 cfm on his 540 making 758 HP...over 700 hp and torque at 5300 rpm... www.motorsbyshooter.com
pslonaker is offline
Old 06-15-2010, 01:51 PM
The old school rule is 2 cfm, for every 1 ci. Example 500 ci motor you need 1000 cfm carb, or 1050.
HighPriority is offline
Old 06-15-2010, 02:00 PM
You can make that power with an 950CFM 4150 flange carb and be a little more fuel efficient and have better mid range.
Most guys go with Dominators, and they are acceptible, but they are overkill for that amount of HP. I have done done both carbs on the dyno and switched intakes and the top end numbers are the same. The fuel usage is a little less on the 4150 carb and the mid range numbers pick up faster.
Either way the carbs and the intakes are about the same price. Flame arrestor may be a little more expensive with the Dom.
jeff1000man is offline
