Any idea where these wires go
The wires for the trim sender should be in the wire harness around the distrib/bell housing area. These will be the 1 male, 1 female end set.
The wires going to the pump are for the trim limit switch, not the gauge. These will have both male ends.
The female should hook to a male that goes to the mercathode control module ground. The other one will run to the gage on the dash for trim.
Thanks,
I went from an efi motor to a carb motor, would this matter. i guess i really have to look around but thus far i haven't seen any loose wires..also it does not have the mercathode..can i just ground the female wire...
also if i can't locate the wire can i just run two wires from the trim sender guage down to the sender sender unit wires..how could i make this work..
thanks again
Q
thanks again
Q
My cruiser didn't have the Mercathode and the wires just plugged into the harness. Take a closer look. I've seen wiring schematics showing it both ways. Not sure what the reasoning is, other than for convience since it is a ground connection.
If I recall ?????, the 2 engine side leads on mine were fairly short (couple inches only)coming from the harness.
The male end should go to a brown w/white tracer wire in harness. The female end does go to ground. So I'd say if all else you could run a single wire to gauge and ground the other lead. Judging from my manual
thanks again,
I was only asking , cause when i sent my harness to the engine builder, i'm not sure if he took that wire out of the harness because i can't find it anywhere...
but thanks again, just waiting for the weather to clear..and i will post some results..
Q
Q
