msd problems
Registered User
msd problems
last sunday went for a long boat ride and after sutting off for about 1 hour i went to start the boat and it would not start,no fire to the plugs.i pulled the cap off my msd distribetor and the small graphite ball that is in the cap that the rotor rides up aginst was laying on top of the rotor,and alot of graphate reasado,sooting,in and around the cap.the center of the cap where the ball used to fit looks as if it melted/corroded awy.i changed the cap and rotor.still no fire.i tested the msd box like the manual says,and the box checks good.i have spark comming out of the coil,but not to my plugs.is the pick-up in the distribter the problem?is there a way to check the pick-up or anyother part of the distribtor?i am running a msd6 marine bow and external rev-liminter,and coil.everything msd.thanks.
Go to the MSD website and download the pdf file on troubleshooting it tells exactly how to and how many ohms the distributor pickup is suppose to read. As well as other info you may need........................................Rjr... ............................
1 Post
Fixx
turn the ignition on, run a feeler guage between the pick up and the star wheel,,should get a spark out of the coil,,if not replace he pickup..
if thats notit then you may have a toasted coil wire
i understand MSD is coming out with a new much smaller ignition package that you can carry on your key ring so that you always have one with you to get home with when their original stuff strands you.
they are available in 6 packs in case the trip is more than 25 miles
the magnetic pickups(made in china ) are junk !! they fail regularly...the older ones lasted well the newer ones that cost about $25 so figure how good they are...you are better off running a aftermarket HEI more reliable....parts available at any parts store...
Registered User
yea,i was always told you better carry a spare unit,so i did,box,coil.i never thought i would have to carry the whole plucking ignition with me as a spare.
