Rinker Captiva 262 SS performance ???
#31
4mula,
I would completely agree with you on the slip and speed. As a matter of fact, the whole reason I started this thread was because I felt the boat had more to offer.
As far as the hook is concerned, I feel that it is not an issue but will absolutely check for it when the boat comes out of the water.
I changed my position a little after I was provided with some additional information. As the chart and picture above show, my boat is on par with the HO and 500 until about 4600. My boat simply will not pull any more revs. The other boats seem to really gain efficiency (less slip) with more revs and the labbed prop setup.
The Raylar cam and ECU flash should get me to the HO specs if not even better. The Bblades recommendation and prop will also get me there.
#33
4mula,
Attached are a couple pics of his 2002 262 SS (it's currently for sale). I remember now that the 262 does have a very unique pad style hull. You can kind of see it in the stern pic. Maybe it just takes a little more power (like you are working on) to get it over the hump and break free to get that slip number down.
#34
I have seen that boat online. I think this is a better shot of the hull as it seems to be pretty unique. I just haven;t seen anything similar in my limited experience.
#35
I've dyno'd several 496 Mags. They make maximum HP at 4600 RPM. It starts dropping after that. Fact is they make just about the same power at 4400 RPM. So, it sounds like the engine is performing correctly since it is pulling a 24" prop to the correct RPM(assuming your tach is accurate). Something is keeping the hull stuck to the water. Was the picture you posted with the boat trimmed up? It looks like there is a lot of hull in the water if it is.
#36
#40
Jason
I had a similar issue. We had the boat to numerous marina and no luck. Finally I had a tech at robberties marine in ulster ny and he was the only one to fix my problem. My issue was a faulty nock sensor. Basically it would retard the timing and never make all the power. Try it you never know.
