Trigger coil & Coil symptoms?
How can you tell if your trigger coil or coil is starting to get faulty?
Having hesitaion, and two suggestions have been, replace the coil and replace the trigger coil under the distributor cap.
happy to replace what is broken, but hate spending money on parts that aren't (and still having a boat that hesitate over 3500 RPM)
http://www.offshoreonly.com/forums/g...ml#post3183294
Just took out the trigger, looks o.k. but one terminal looks black coated, and needs cleaning (strange, does not look like corrosion)
Check the OHMS.
OHM meter ont eh R x 1K setting.
Green & white = 3 (3,000)
and the Red & White = 9 (9000)
Check the OHMS.
I recently changed the trigger, cap and coil on my boat chasing a miss in the 3200 to 4000 rpm range. As it turned out the tachometer was bad. In that particular sweep of motion it stole enough spark to cause a bad miss. WOT or below 3200 was fine. Something to think about on old boats with newer motors.
Could you disconect the tach to check if that is the problem??
