2008 700 sci dying out
Hey guys Im trying to help a friend out that has a 2008 cig with twin 700sci engines ,the port engine will die when going through a no wake,starts right up and then runs fine,we switched the iac and didnt help.we checked the min idle setting and its fine,checked tps reading which was fine,no stored codes,last time it happened we could tell it was going to die because we felt the engine load up like it was flooding out,tryed accelerating in gear and had a hard time getting over 1800 rpms ,shut the engine off and restarted and then was fine,
any ideas? Thanks
any ideas? Thanks
any ideas? Thanks
any ideas? Thanks
Heres an update
If I unplug the Interuptor/anticipation switch and drive the boat with it unplugged the boat runs great and does not die.
I replaced the switch and the boat started dieing out as soon as we pulled out of the boat lift,I unplugged the switch and the boat then runs great,
so my question is what is the correct way to adjust the setting on the switch? I backed it out and on 3 times out it has died one time,better but not 100%
what would happen if I left the switch unplugged? would I hurt the ECU?
Thanks for any help.
