OMC King Cobra nose cones >
Old 08-27-2010, 01:50 PM
Default OMC King Cobra nose cones
Posted this in the drive section last month w/ no results so I thought I'd try it here.
Read an old post where a guy saw speed improvements on the KC drive @ lower speeds. My boat is slow compared to most boats on this forum but hopefull a nose cone may give me the same results. Anyone else see the same results below?
"I have talked to hydromotive about nose cones on my bravo 1 and they have told me twice that i will gain nothing on a bravo 1 unless you are going over 80mph. I did put one on my king cobra and it picked up about 2-3mph and i was only running 55 stock so go figure"
Itsallgood995 is offline
Old 08-27-2010, 03:09 PM
I have a 23 Scorpion with a Cobra drive which is shaped like Your King cobra, I gained about 2 mph with a nose cone. If you look at the shape of the lower it is kind of blunt in the front. I think I just gained a litle more from the better flow back to the prop. JMO
doggiedave is offline
Old 08-27-2010, 03:48 PM
I have a volvo penta sx. I believe the drives are similar? Would I see performance gains even though it only runs 55mph?
Perlmudder is offline
Old 08-28-2010, 07:25 AM
coolrunning racing
mrv8outboard's Avatar
Also if you do decide to install them the lower housing is the same as the V8 outboard.
mrv8outboard is offline
Old 05-23-2011, 12:16 PM
Did you ever go through with this, and what did you find?
brivander is offline
Old 05-23-2011, 01:08 PM
Never did, ended up converting over to a bravo set up.
Wish I would have tried it first, it seems worthwhile.
Old 06-02-2011, 08:50 AM
I in the middle of the same dilemma, how long to keep the King Cobra...I was thinking about converting to Bravo 1 at the end of this season...
Were you able to find the nose cones somewhere, and what were the prices?
EDIT:
Just ordered this http://www.hydromotive.com/nosecones.html -- it'c completely unclear from the website but the MC HC1 B fits the 1990 and later King Cobra, the lady said at 60-65 mph a 2-3 mph gain would be pretty typical with this drive, if that's true it will be the cheapest 2 mph I ever paid for. Hell if it gets me 1 mph I'll still be ecstatic....
Old 06-02-2011, 06:04 PM
Cool, the Hydromotive was the one I was considering also.
Let us know how it works out.
Old 06-14-2011, 09:41 AM
Fits horribly, it fits like a glove on pre-1990 Bravo 1 (did some test fits on baots in the rack at my marina. I called and they siad it takes more work but I can use it on the post-89 King Cobra (Cone Clutch Style), but it's really not even close...Any other ideas? I really want to do this, even if nothing more to protect my drive, with all the rain this spring there is a TON of crap in the water this year....
Old 06-14-2011, 09:45 AM
Which units are compatible with the outboards?, the pre-90 King Cobra or the 90-later King Cobra, they are pretty different....
http://www.allamericandriveservice.com/OMCCobra.html
