502 MPI Q - Sensors >
502 MPI Q - Sensors
502 MPI Q - Sensors
Old 10-14-2010, 07:33 AM
Default 502 MPI Q - Sensors
What sensors does the standard 415Hp, 502 cu. in. MPI system use? Does it use an O2 sensor, or mass air sensor or anything like that?
wjb21ndtown is offline
Old 10-14-2010, 10:28 AM
No,
MAP, Knock, Idle Air Control (IAC), Throttle Pos (TPS), Engine Coolant Temp.
Distributor would serve as the cam/crank pos sensor for injector timing.
4bus is offline
Old 10-14-2010, 05:23 PM
Originally Posted by 4bus
No,
Thanks 4bus!
