What do you guys put in the gas tank to keep the fuel from gunking up?
It may not "gunk up" in 6 months but it is definately JUNK in that time frame. Mocern blended fuels have a max 60 day shelf life. Many of the volatile hydro carbons evaporate away in as little as 30 days.
I sure would not run 6 month old gas thru a new engine or any engine for that matter save maybe my lawnmower.
Pump it out and start fresh.
I have used StaBil for years and find it works very well. I have even gone a season without using it (not planned) and it still works in the tractor although I would not run it in the boat.
All the marinas around here have had better luck with k100 than startron with the e10 and I would just drain the tank and put fresh in when you get the new engine in I just put two motors in mine and figured fresh fuel was worth not chasing contaminated fuel issues when tuning the engines
We dump in the Stabil every year...but does anybody REALLY know the if it works? It would be nice to see some real test results of what Stabil actually does for the octane level of gasoline after 6 mo vs no Stabil added. Remember STP?
Charter Member #232
How much do you guys think you need to do to mix in the stabilizers? I was going to add it before I trailered home but forgot to. So I just dumped it in and ran the motors for about 20 min. each while I winterized. Should I pull the boat around the block?
Put your best foot forward!
I usually dump a bunch in before I go for the last ride, I figure that mixes it up pretty well. I also try to run the tank as low as possible, then throw in some 93 at the start of the season. I quick lap around the block couldn't hurt to get it mixed into the tank.
